Aight, i need some Electrical Gurus in here..
So everytime i start my car, my lights will flicker rapidly, and my voltage needle will bounce a tinch, but very rapidly also reading about 15-16volts.
The other night i started my car, and the damn thing alost died on me. Rough idle, low voltage, dim lights. It took a minute to warm up, then my passenger window wouldn't roll all the way up, seeming like it didn't have enough power. Eventually everything went back to normal.
Last night i get out of class, start my car up, and theres a "humming" sound thats comming from my engine bay. It would go away with increasing rpms, and return at idle. After a minute or two this went away and i haven't had a problem yet today.
SOO, i go to autozone this morning and have my alternator and battery checked. everything checked out allright. I still think its my alternator. Sometimes my voltage reads really high (16) but mostly reads below 13. Symptoms point to alternator, but the guy at autozone it might be a bad ground.
What you guys think? Sorry for the long post, but i have to get my descriptive writing skills in there lol
i woulda said bad ground somewhere as well.
The fact that the humminnnnng is coming from the engine bay and flickering, sounds like you may have rusted ground leads or lose grounds.
possible voltage regulator in your alternator, you could try taking off your belt an giving the alternator a spin with your hands if it sounds anything but smooth take it off and have it checked a bad regulator will fry you alt. 15-16v is too high
parts guys work at autozone not autotechs
I would just check the battery termainals, wiring conections at the alternator and check the plug wires and coil packs to make sure they are tight and free of corrosion. Also check the fuse panel under the hood for loose or blown fuses.
wiring problems can be a royal pain, trust me.
