Passenger window goes down but not up
Old 10-15-2007, 10:07 AM
Mr. Camaro's Avatar
Default Passenger window goes down but not up
Just like the title says. It goes down fine but not up. Its not the motor, I've tried a rebuilt motor and a brand new one and it did the same. And its not the switch (I switched the lock switch with the window switch and it did the same thing) and it doesnt work from the driver side master switch either. Has anyone else had this same problem? I know its a wire messed up somewhere but I dont know where and I hate wiring so I dont have the patience to find it If anyone has had the same problem as me please post what the solution was. Thanks.
Old 10-15-2007, 11:16 AM
SparkyJJO's Avatar
When you say it doesn't go up, does it just try then fail to make it up or not budge at all?
If it just goes up a bit then fails to finish then you need the autotrix passenger window fix
Old 10-15-2007, 12:24 PM
BIG_MIKE2005's Avatar
Agreed.
Old 10-15-2007, 12:50 PM
2001NBMZ28's Avatar
Does it not work at all from the drivers side switch or doing the same thing? I suspect the dual switch.
Old 10-15-2007, 12:59 PM
2001NBMZ28's Avatar
http://shbox.com/1/pwr_window_schematic.jpg
Old 10-15-2007, 01:11 PM
Mr. Camaro's Avatar
no it doesnt do anything from either switch, thats why I suspect wiring. I hate digging for messed up wires! It wouldnt be a big deal but I live in texas and my A/C just crapped out on me
Old 10-15-2007, 04:34 PM
Closed ex-Sponsor Account
autotrix's Avatar
Thanks for the ups guys!
If you would like I could email you the diagram for the window circuit- I know that you already stated that you didnt like wiring but its better than paying someone else to fix.....or is it?! You might want to start by tracing your power path, start at the fuse and work your way to the door. I hope this helps, let me know if you want the diagram
Quick Reply: Passenger window goes down but not up
