P0135x2, P0171x2, P0161, and P1133 PLS HELP!!!!
Old 10-26-2007, 07:36 PM
VtecDis's Avatar
Default P0135x2, P0171x2, P0161, and P1133 PLS HELP!!!!
got these 6 codes when i gutted my cats... my question is, if i get some 02 sims, will those delete the codes? if i get a Predator Programmer to delete the codes, will it get rid of my SES light??
Old 10-27-2007, 05:56 PM
dependonauto's Avatar
sounds like more than just cats
Old 10-27-2007, 06:45 PM
keliente's Avatar
All of these codes deal with bank 1, so they are most likely related.
P0135 and P1133 refer to the first oxygen sensor, so it sounds like it is bad and needs to be replaced. P0171 means bank 1 is lean...bet if the 02 was replaced all three codes would clear up.
Old 10-29-2007, 12:26 AM
VtecDis's Avatar
ok i will try that.. thnx guys
Old 11-09-2007, 10:09 AM
VtecDis's Avatar
just to clarify, p0135 and p0161 refer to my rear 02's right? and the p1133 is referring to my front driver's side 02 which needs to be replaced? if get the rear 02's tuned out, can i reuse them on my front driver's side 02 instead of buying a new one??
Old 11-09-2007, 11:58 AM
PunkerPontiac's Avatar
guys...he said he just gutted his cats. of course he is going to get codes. you'll have to get a custom tune to delete the codes.
Old 11-09-2007, 12:17 PM
keliente's Avatar
P0161 is for the rear. The others are for the front 02's. P1133 is insufficient switching for the front 02 (i.e. it is not reading fast enough). P0135 is front sensor heater malfunction.
Code Definitions Click Here
You need to replace bank 1 sensor 1, and have the rear o2's turned off. You can use a rear 02 in a front 02 so long as its good, and after gutting cats and running it there's no guarantee that both rear sensors haven't been fouled out.
Old 11-09-2007, 12:18 PM
keliente's Avatar
No kidding but half of the codes he posted are for sensor 1, which is in front of the cat.
Old 12-08-2007, 02:46 PM
VtecDis's Avatar
finallly got 02 sims. but still got the p0135 code. i switched the rear 02's to the front and reset my car's computer. no SES light, no misfire now
thanks for all the inputs.
Quick Reply: P0135x2, P0171x2, P0161, and P1133 PLS HELP!!!!
