Driver's side light keeps going out, symptoms?
My drivers side low beam light will turn off shortly after I turn the lights on. It will turn back on if I go over a bump hard enough, as though something is loose and not connecting right. I double checked the connections and can't figure it out. What is usually wrong when a light intermittently keeps going out? Even after replacing the bulb and cleaning the connections?
mine...did the same thing... finally i replaced the wiring and got a new light housing and all is fine.
now my passenger one is acting up...one minute it works....another it doesn't....
i had an issue with that a couple yrs back, replaced the one bad light that i had and still had the problem after a couple days of TSing on my own finally gave up and tookit to GM. Ended up being a relay somewhere under the dash think is was about 150 to have them fix it
Location: The dirty taint of the country. ...Los Angeles
