coolant fans
coolant fans
Hey guys i have 98 T/A and i cant get my fans to go off i already changed my coolant switch cuz temp guage wasnt working ethier it fixed that problem but not the fans.. Any Ideas?
Is the SES light on? If it is I'd get the code(s) read. If the light is not on you can try resetting the PCM, won't hurt to try other than the idle being grumpy until it relearns.
Turn key on, don't start car
Pull PCM BATT and PCM IGN fuses in engine compartment
Wait 5-10 min
Turn ignition off
Replace fuses
Wait 5-10 min
Turn ignition off
Replace fuses
