battery question
battery question
car started losing charge BAD and dropped to 8 volts, the headlights dimmed, but it was running still and idled even without feathering or anything
is it a just pure dead battery or are there some sensors or grounds i should check???
help its unstartable without a jump lol and i'm in a parking garage
well idk if this is gonna fix the whole problem, but my battery was in fact DEAD, and the wire on my alternator was loose/stripped so i bought new of both, and if it won't charge now...i'll start attacking grounds, i dont listen to the radio/use cruisecontrol/have ac so i could unplug those, my drivers side window is messed up if that could be causing it
Well the CC and ABS stuff that works off the brake pedal is normally closed so if those modules are messed up it will drain powere even with key off. It isn't likey but super easy to test and get out of the way. Just a thought. Keep posting. We can get this solved.
I put a lock washer on my alt excitor washer and that stopped it from coming loose anymore.
