car loosing power after i turn it off
my car is turning its self off sometimes after i turn the ignition switch off. like the battery gets disconected when i turn it off. it happens in abotu 1 out of 10 time i turn it off. when i go to turn it on after this happens i get low idle and then it fluctuates (sp?) between 200 and 800 rpms. if i turn it off and back on after that its fine and does its normal thing. i recently removed the starter and replaced it (got it tested at autozone, checked good) i also replaced the battery due to starting problems (the reason i removed the starter). i also replaced the clutch safty switch or what ever you call it and installed a diablo tune on it. its the tune that comes from the company nothing like a custom tune from myself. i also took off and put my headers back on to replace the gaskets an dto put on my exhaust. does anone have a clue what it could be?
thnaks
kyle
thnaks
kyle
i have the same problems. Car kept losing power and its my battery cables that aren't making a great connection sometimes, usually during the hottest days. I have stereo system wire couples with the positive battery terminal and the connection is troublesome. Id check that out.
