Heater Stopped Working! HELP!
CARTEK Racing
Okay so here is the problem.
The blower motor on my heater stopped working. I did remove the passenger airbag, but I do not believe that I cut any wires since I never had to totally remove the dash, I only pulled it forward about 8" and it have me enough room to wiggle out the airbag.
This is what I have learned so far:
1. The HVAC fuse is NOT burned.
2. There is power going to the fuse when HVAC system is turned on.
3. There is power going to both switches. (fan speed control and area control)
4. There is no power going to the connector that is connected to the blower motor under the dash. Connector has 2 wires [purple and black]
a. when I jump the orange to purple wire on the back of the fan speed switch, there is still no power going to the blower motor connector.
Does anyone have any ideas? Similar experience? Anything?
I would really rather not have to pull the dash forward again, but if I have to then I have to.
HELP!
Thanks
Alex
HELP!
Thanks
Alex
