Fog Switch Light Bulb
I noticed that on the fog light switch the light wasn't lighting up when I had my fog lights on. So does anyone know how I go about changing that bulb or so? Or even the bulb number? This is for the 1999 Camaro. Thanx.
believe it's an LED bulb and GM will tell you you need to buy a new switch. But you can take it apart carefully by prying off the back. If you look close there should be 4 tabs that hold it together on the sides, use a flathead screwdriver. I haven't changed the bulb but I have taken them apart to change it from a momentary switch to on/off. You'll probably be able to find the right bulb at radioshack if you get to it.
