Seems like alternator has failed - what to check for first?
Today while driving I saw that voltage is dropping constantly, and in a few minutes it dropped below 8 volts (on the dash) and the car stalled - right when I managed to park it.
Seems like I was running on battery.
What to check first?
Car is 98' TA
Car is 98' TA
Yes it is true, an alternator is not meant to "charge" the battery, mainly to supplement it and "keep" it charged but yes you can fry the voltage regulator pretty quick doing that.
If the car still runs, you can take off the Negative battery cable(while its still running) and if it stops after a min. or so the voltage regulator(inside the alt.) is shot.$.02
Good info in this link:
http://www.aa1car.com/library/2004/ic120434.htm
Is anyone an ASE mechanic in here or are you just reading stuff off the internet. Not trying to be a dick just curious
I'm not an ASE, just someone who has worked on cars for ~ 30 years. I'm an electronics technician by trade, military, industrial, and now with the USPS. I have rebuilt alternators (back in the day when it was cheaper or easier to rebuild than to replace), so they aren't mystery boxes to me. An alternator generates AC, 3 phase on every one I've worked on. The 3 sine phases are fed to diode rectifiers. In older alternators, these are discrete devices in metal cans pressed into the back of the alternator case. Newer ones use a diode bridge, looks kind of like a big heavy duty chip.
All diodes have max current ratings, and while power rectifiers can supply large amperages, they too can literally fuse into a silicon lump if overloaded, or just open to infinite resistance. If they fuse, they can instantly become a straight short. So instead of rectifying the AC coming off the alternator windings, they shoot it straight into the vehicles DC supply, obviously not good.
Diodes can fail on their own, but if someone were to replace an alternator, then crank up the engine with a jump start, a run down battery is going to want to draw a lot of current. Unhook the jump and the alternator is going to try to supply all the current alone and this is where the danger lies. It can also present a bit of a risk to a car that might be providing the jump as it's alternator load will increase too, not to mention spikes from hooking and unhooking cables. Batteries in cars where the alternator failed are typically run down to completely dead trying to keep driving... worst case scenario.
I've replaced a lot of alternators and noticed a few years ago that they started to put a note on the output stud of many of them. Says something like "WARNING! Fully charge the battery before installing the alternator. Failure to do so many result in the new alternator failing!" I guess they had a lot of returns due to this and started including the notes. It's best to just play it safe and fully charge the battery. JMO
