Just Changed My Oil.. Check Gauges And Change Oil Light On
I just changed my oil not even 5 miles ago (today). Now the check gauges light is on. The oil change light has always been on ever since I bought the car which was 2 weeks ago but I haven't driven it much since I bought it.. Maybe about 250 miles since. Oh and by the way, How much oil do these car's hold? It's a '00 Firehawk M6.. If that helps. I had two LT1's and both held 5 quarts. Not sure if the LS1's hold more oil because they have a bigger crank case or oil pan or something. Thanks for the help.
I put 6 quarts in mine...But just use THE DIPSTICK to see how much it needs
To get rid of the change oil light, turn the key to the on postion (engine off) and hold down the trip meter reset button until you see the change oil light flash. Then its reset, and it'll come on again when the computer calculates when it think the oil needs to be changed again.
Hope that helps you.
To reset the change oil light, you just have to hold down the trip reset. It should reset the light for the change oil. As for the check gauges, how much gas do you have in the car? If you are low on gas it will make the check gauges light come on. LS1's take 5 1/2 quartz of oil.
If you are too low on gas, the fuel pump can overheat and die - I think it's $400 or so to have replaced by the dealer... I've not had it happen but have read of others experiencing this...
