Airbag Light?
There's already a guide on this... It's listed in the stickies, open with Adobe Reader.
https://ls1tech.com/forums/attachmen...1&d=1192338016
Thanks Haacer, however I don't think this will help me much as I have a 95 and they used different SRS mods until 96. The 96-up has one sensor/SRS comp, however I have 3 sensors and a SRS comp. I don't think mine is as smart as the units that work with the OBDII cars. Any ideas/suggestions?
I can't remember if this system flashes the code at you, but you could try counting the flashes when you first turn it on. If it gives you a code in this manner it will be two digits... For instance flash pause flash flash flash for code 13. Try that... Otherwise I think you're gonna need a scanner.
You can always start replacing parts, but without the code you don't know why that light is on.
