vats problem!!!!!!!!!!!111
Old 12-04-2007, 08:42 PM
fuseone's Avatar
Default vats problem!!!!!!!!!!!111
ok vats light came on and it didnt want to start. took it to the dealer they didnt know it is say the cylinder and all looked good so do the wires. now i read on hear that some one said it was bad ignition relay what i want to know did you test and figur that out and some one also said a bad alternaotor how did you figur that it was causing that problem with the vats? and thanks for the help in advance
Old 12-04-2007, 09:02 PM
carado1984's Avatar
i bet you that its the ignition relay. and i recently wired resistors in to bypass mine. Let me see if i can find the link to the thread.
Old 12-04-2007, 09:08 PM
carado1984's Avatar
read my last post at the bottom of the thread that explains how to do it.
https://ls1tech.com/forums/showthrea...216&highlight=
then print out this diagram and my last post and you can do it.
http://shbox.com/1/air_bag_disc_2.jpg
Old 12-04-2007, 09:21 PM
carado1984's Avatar
one more thing.. there are i believe 12 or 15 different chips in our keys. All the chip is, is a resistor. Take a multi meter and touch the negative and positive to the opposing sides of the chip and it should read somewhere between 1k and 15k ohms.
Find the correct amount of resistors that make up that amount of ohms and if it says something like 2.994 ohms you dont have to be exact with your resistors.. For example three 1k ohms would do the trick. Try to get within 50-100ohms. The resistors in the key are not exact. They are more within a range so as long as your close with the resistors then youll be fine.
dont sauder them first. just twist them together end to end..
and twist. Thats my effort at drawing a resistor. Then wire them like i said and if you did it correct, when you turn your key the security light should come off. Then start it up. If it works, turn it off and sauder the twisted resistors end to end then wire them in and tape them.
Oh and by the way... Make sure you disconnect your battery. ha.
Old 12-04-2007, 09:56 PM
fuseone's Avatar
well that is the first thing i did before i took it some where was check the keys and they were good. i check them with a ohm meter
Old 12-05-2007, 09:59 AM
fuseone's Avatar
what i want to know is how they figured out it was a igntion relay. or how the one guy found out it was is alternator?
