WOW . . what a klunk!
Drivers rear . . . Hit a piece of bubble gum and it sounds like the shock is coming through the well wheel. I checked the shock and it's tight. Anyone with any thoughts on what might be the problem?
As always I appreciate your help as you guys know way more than me.
Where should I start?
Ron
Ron
are you positive it is the drivers rear. what size exhaust do you have and does it run over the axle. i could never tell where the noise you were describing was coming from. i tried to shake the exhaust, but it would move. it was very close the the pan hard bar. so one day i just stuffed a wrag in between it and there was no klunk. until the wrag fell off. best of luck.
Thanks for the replys.
I have that exact same noise. Anytime i hit a bump in the road it follows with a loud clunk noise. I have checked exhaust and lower control arm bolts and everything is tight.
My noise it coming from drivers and passengers rear. I wish someone had an answer to this problem.
* Update * Both bushings on the driver LCA were toast. I put a new set of BMR's I was going to put in the SS but they were needed in the Formula. So goodbye klunking noise.
Thanks for all your suggestions.
Ron
Ron
Thanks . . . I also did the while i'm under there I put new KYB shocks in also. Tomorrow i'll do the fronts. 108k on the original shocks, I figured they were due.
sscamaro02, the LCA are not that expensive. Get a set from one of the vendors. To change the bushings you need a press to that. Press the old one out and to press the new ones in IIRC.
The bushing that connects to the rear was in the worse shape on mine.
