P0354 Ignition Coil D Primary/Secondary Circuit Malfunction - LS1TECH
Thread Tools Search this Thread
Old 12-13-2007, 10:01 PM   #1
BLULS1Z28's Avatar
Default P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
what coil is "D" so i can check it to see if there is any cracks or broken wires
BLULS1Z28 is offline   Reply With Quote
Old 12-14-2007, 03:45 AM   #2
01WS6/tamu's Avatar
Anytime I have seen that code set it has usually been a coil that bit the dust. The coils are labeld a-i in for diagnostic purposes. I'll have to look at alldata in the morning at the shop to see which coil driver circuit D is for.
01WS6/tamu is offline   Reply With Quote
Old 12-14-2007, 10:56 AM   #3
P0354 is Ignition Coil 4 Control Circuit
2001NBMZ28 is offline   Reply With Quote
Old 12-17-2008, 07:06 AM   #4
which is? cause I also have this code, and don't know what should I be checking?!
wajouba is offline   Reply With Quote
Old 12-18-2008, 05:19 PM   #5
biggb1783's Avatar
biggb1783 is offline   Reply With Quote
Old 12-18-2008, 07:23 PM   #6
my question was said in a wrong way... I ment... which each piston was... on the block itself... how do I know this is number one, that is number 3... etc...
Old 12-18-2008, 08:08 PM   #7
Firewall
8 7
6 5
4 3
2 1
Radiator
Old 12-18-2008, 08:17 PM   #8
thanks alot guys
Old 12-16-2011, 10:52 PM   #9
Default P0354
Hey guys-
After reading this post concerning the code, "P0354 Ignition Coil D Primary/Secondary Circuit Malfunction"
I have 2004 F150 V8 5.4L trition.
I have the same code and after reading ya all posts. I replaced all spark plugs.. one spark plug broke on #1... I ordered a broken spark plug remover called, " Lisle #65600" Which worked fanastic!
After all that, I replaced #4 coil... after a 2 mile drive test, engine light came back and the code is the same even after I erased the code before the test drive.. the truck drove shaken like it's misfire... I am at loss... anybody got an idea what I am dealing with on this?
Mikeshaft is offline   Reply With Quote
Old 12-17-2011, 06:25 PM   #10
wrencher
wrencher's Avatar
Quote:
Originally Posted by Mikeshaft View Post
Hey guys-
Your lucky it only broke one plug coming out.
Cylinder 4 is the rear most on the passenger side of a ford.
Real bad design IMO the heater hoses are on top of it where they seeping some?
It will take out the coil's connector in some cases.
wrencher is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
LS3 Coils maybe trade for D585 truck coils buick70bbc Parts Wanted 2 10-26-2016 03:23 PM
Truck coils 00loudchevy Parts Classifieds 0 09-24-2015 01:33 PM
Wtb "1" truck coil with heatsink ice95z Parts Wanted 2 02-06-2013 06:27 PM
D585 Coils Firing danlee Generation IV External Engine 2 06-25-2012 08:27 PM
d585 heat sink coils 350SS Parts Classifieds 0 06-24-2010 01:34 AM
Tags
circuit, circut, code, coil, d, fault, ign, ignition, location, malf, malfunction, p0354, primary, primarysecondary, secondary
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
