Please Help w/ Check Engine light CODES
Okay my OBII port is reading now thanks for the help. So now I am throwing four codes p0102 , p0141, p0135,p0155 the one that gets me the most is the mass air flow code? Any suggestons or info is greatly appreaciated.
You're throwing three 02 heater codes and a MAF code. First thing I'd check is the ENG SEN fuse under the hood, the 02s and MAF on are the same circuit - along with the skip shift and reverse lockout solenoids if you have a M6 car. Buddy of mine threw P0102 when an 02 sensor wire harness melted against one of his headers. Just a guess without knowing if you have any mods, make a short signature so people can help you better.
