Dead spot 2500
Old 12-17-2007, 07:32 PM
Alt
Alt's Avatar
Default Dead spot 2500
Mid throttle I have a dead spot at 2500rpms, car doesn't want to get up and go past it unless I really get on it. Full throttle, its not there. Any ideas on what could be causing this? I am without a scan tool so I am kind of shooting in the dark. Any help would be appreciated. Thank you!
Old 12-17-2007, 07:53 PM
Blackhawk777's Avatar
My guess is a fuel filter. Give that a go.
Old 12-18-2007, 11:47 AM
Alt
Alt's Avatar
Say it is the fuel filter, what is it that keeps it from moving fuel at part throttle that doesn't stop it at full throttle? Is there a correlation there?
Old 12-18-2007, 02:09 PM
jmm98LS1's Avatar
Time for tune-up items: fuel filter, plugs, clean maf sensor.....might run some seafoam through it too.
If you wanna do a quick check to see if your maf sensor is dirty and needs cleaned, unplug it and go for a drive.
Old 12-18-2007, 08:23 PM
Alt
Alt's Avatar
I did the plugs and wires when I changed my headers. Ran seafoam through it a month prior. So I assume that all that is left is the condition of the MAF and the fuel filter.
Old 12-20-2007, 12:09 PM
Desert Rat's Avatar
I had this too.
Tried:
Seafoam. Didn't help
Fuel Filter. Didn't help
Cleaned the mass airflow sensor. Made all the difference in the world.
Old 12-21-2007, 04:41 AM
Alt
Alt's Avatar
I descreened my MAF for the dry shot, I guess I'll hit it with some electrical contact cleaner and clean it on up. I appreciate your input Desert Rat, looks like I have to add that to my list once it gets above 38 degrees up here.
Old 12-21-2007, 04:45 PM
Alt
Alt's Avatar
Wait a minute, the car doesn't look for the MAF unless you're above 4k rpms.. guess my fuel filter is the culprit then.
