Issues with window motor
I bought my car about a month ago and the passenger side window motor was out which he said he replaced but went bad so I replaced it about 2 weeks ago and went bad again today.
Make sure the window motor you get has a warranty. Then check and make sure you don't have resistance that would cause the motor to wear out. Might also consider buying the www.autotrix.net passenger window kit.
Okay I took it out and pluged it in while it was out and it started working again so I put it back in just to hold on and it worked. So should I just take it and get another one since its under warranty or just put it all back together? Oh I forgot While it was all together before I took it off I tried it but it didnt work but I felt the motor try but nothing.
