Whistling
Old 12-26-2007, 01:14 PM
zmanx's Avatar
Default Whistling
I have this very loud whistiling noise comming from around the lower half of the motor, It only does it at low idle and seems to take a minute to build up. Ive been told its the air pump, what do you think?
Old 12-26-2007, 01:19 PM
87gnx's Avatar
Does it go away after a min. or so??
Old 12-26-2007, 01:23 PM
zmanx's Avatar
as soon as I give it a little gas it goes away,But I dont think its a belt it sounds more like air and it seems to bleed down when I turn the car off.
Old 12-26-2007, 01:31 PM
87gnx's Avatar
The air pump in wifeees Camaro does that, it sounds like a jet engine for a min. or so. If it isn't effecting your performance or fuel mileage, I wouldn't worry with it.$.02
Old 12-26-2007, 01:36 PM
2001NBMZ28's Avatar
Don't know what it is, but if it only happens on cold starts for a couple minutes could be the air pump. To verify you could pull the AIR PUMP fuse under the hood while it's making the noise and see if it stops.
Old 12-26-2007, 08:05 PM
kw's01z28's Avatar
my car does that when i start it when its cold , i like it sounds like i have a super charger till it warms up to about a 100 then shuts off.
