oil leak rear main seal ?
Old 01-13-2008, 11:42 AM
ssblackss00's Avatar
Default oil leak rear main seal ?
ok I have a oil leak I thought may be the crank sensor but I pulled the starter today and it is not coming from the sensor. I thought that it might be the rear main but I have read that it would be coming out the hole in the bottum of the bell house but its not it is running down the sides more on the passenger side about 10 times as muchas the drivers side and collecting by the hole where the bell housing meets the engine. ANY help or idea of what it could be would be great.
Old 01-14-2008, 05:03 PM
blkbird's Avatar
I have been chasing an oil leak myself. Its come down to crank sensor or not enough RTV with the new oil pan gasket. Its doing the same things as you are describing. So far ive replaced the rear main seal, rear cover gasket, valley cover gasket, timing cover gasket and the oil pan gasket. Very frustrating indeed......
Old 01-14-2008, 05:55 PM
I cleaned the whole under side of the car got it all off it looked like a new car for about 2 hours until I drove it then it was covered in oil. someone told me that there pcv system was to blame because the did something to it all I have done though is change pcv valve so i am putting the stock one back in tonight. As weird as that sounds if it stops leaking oil I will be happy even though I will never know where it was coming from. have you done anything to the pcv system.
Old 01-14-2008, 06:29 PM
shoemike's Avatar
if the crank case is not venting that
will cause oil to seep through gaskets.
Old 01-14-2008, 06:30 PM
blkbird's Avatar
I changed the pcv valve to the updated version for the oil consumption issue but that didnt affect anything.
Old 01-14-2008, 09:55 PM
yea thats what I did to but I am going to change it back just to see what it does.
Old 01-15-2008, 05:36 PM
blkbird's Avatar
Any luck with it???
Old 01-15-2008, 05:53 PM
have not driven the car will let you know if it works got my fingers crossed
Old 01-22-2008, 07:54 PM
ok it is still leaking I think it may have got worse
Old 01-23-2008, 09:48 PM
blkbird's Avatar
Back to the drawing board, i guess.....
Old 01-24-2008, 11:39 AM
I thing im going to pull the intake manifold this weekend and look around back there I got to get this fix it is driving me crazy!! still no luck finding yours?
Old 01-24-2008, 12:31 PM
DaveH71's Avatar
Did you check for the Famous intake manifold leak? By what your saying thats what it sounds like it is, i have those exact symptoms just not as bad and im just to lazy to fix it. After your car has been running wait for it to cool and feel around the back of the intake for any slime or wetness. if its wet then the manifold is your problem
Old 01-24-2008, 05:19 PM
blkbird's Avatar
I replaced my valley cover gasket also but its still doing it as well. I cant do crap to it right now since its in the shop after the wreck i had.....
Old 01-25-2008, 03:06 PM
that sucks man well I WILL fing it tomorrow when I take the intake off and what ever else must come off to find it
Old 01-25-2008, 04:35 PM
blkbird's Avatar
Good luck with it.
Old 02-03-2008, 12:24 PM
ok not sure if these two problem are related but now the car was low on coolant, i just noticed DaveH71 post what is the intake manifold leak? since it was low on coolant could it be a head gasket also the oil looks fine went i pull the dipstick out so no coolant int the oil.
Old 02-03-2008, 04:05 PM
NightRider2000's Avatar
Oil leaks can be tough to find. If you can't see exactly where it starts meaning if your valve covers are not leaking what is the next highest thing on the motor that is. Honestly get a can of brake kleen and clean it off thoroughly. Put some dye in the oil and drive it. then you need to put it up and use the light. I work at a shop so I don't know where to by the light to shine which illuminates the dye but that is a proven method. Pressure test your cooling system before jumping to any conclusions you may not have added any coolant for awhile.
Old 02-03-2008, 04:40 PM
I put a 160 stat in my car less than six months ago and i flushed and filled it then and check it for the next month to make sure it was ok and now all of a sudden the car started to get hot so I checked it and it was low. the intake is coming off this next weekend and going to look for it then Im going to clean it real good first. Is it possible for the intake to be causing the oil leak if it is not sealing some where?
Old 02-04-2008, 04:35 PM
blkbird's Avatar
I dont think the intake will cause that much oil to rundown. Like I said earlier, my valley cover was leaking really bad cuz it was dripping on both sides of the motor. Now its only on the passenger side. Ill hopefully get my car from the shop this week and can continue hunting down my leak. Once you take the intake off you can get a better look of things.
Old 02-18-2008, 05:39 PM
I THINK i FIXED it there was very large crack in the pvc hose that connects to the passenger side valve cover so I replaced it, we will see that happen over the next few days. After all I have replaced trying to stop the oil leak it was a hose that discount gave me for FREE !!
