Few Electrical Issues (I think)
Hello,
I recently did a motor swap and everything went together with a few issues but I solved those with a little help. But now I have a few new problems which I just cant quite solve.
I have the low coolant light turning on and off. Sometimes when I start the car the low coolant light is on and then it turns off and visa versa. But I have plenty of coolant by the overflow dipstick and the car does not over heat. So I am thinking sensor. Where is this sensor located so I can change it. And is it possible for me to change it w/o draining all of te coolant.
My next issue is that my cruise control does not works but my traction control works just fine. I checked the connections and the grounds and I do not know why it is not working.
So can some one shoot me some ideas.
Tilly
Tilly
Coolant sensor about 5 inches under the rad cap on the back of the rad. It's a big square plug, can't miss it. Honestly I hate the things and find them useless.
Not 100% sure how cruise control works on these cars but I'm pretty sure they need a good vacuum source. Check to make sure all mechanical components are functioning properly.
