Is it the Water pump or just the gasket?
Old 01-26-2008, 07:59 PM
meangreenformula's Avatar
Default Is it the Water pump or just the gasket?
I noticed some coolant leaks after walking away from my car and traced the leak back up to the water pump. The car has 107k on it and i know the water pump has been replaced, not sure how long ago. You guys think it is the actual pump or maybe just the gasket? What does a bad water pump look like?
Thanks
Old 01-26-2008, 10:06 PM
beedo's Avatar
There will coolant coming out of the weep hole that is on the bottom of the pump, if its that fix it soon cause it will leak onto the opti and you will run into trouble and have to replace it if it leaks onto it to long.
