Gear Shift Slider
Gear Shift Slider
The gear shift slider on my '98 T/A A4 car is the retracatble or telescoping type. Sometimes, but not always it does not slide correctly and will leave a gap when moving shifter from park to drive. Why is this, and what can I do to get it to slide or open up right??
Thanks.
Thanks.
I haven't run into this problem, but I would try cleaning it.
Remove the plate scrub it with some dilluted simple green or similar. Then dry it off good and lube that area with silicon. While you have it off, a visual inspection may also reveal where the problem is.
Copy & Paste Moderator
