asr
Old 02-01-2008, 03:30 PM
chevguy86's Avatar
Default asr
my 00 camaro z28 did not come with tcs that you could turn off on the dash i have an asr switch for the dash how would i run the wires from the switch to the tcs to turn it off when i have a need to
Old 02-01-2008, 05:11 PM
2001NBMZ28's Avatar
My car didn't come with ASR either. You can't just add the switch and make it turn on and off. ASR/TCS cars have sensors at each rear wheel, 4 channel versus 3 channel ABS, etc. Glad I don't have it, never have to turn it off.
Old 02-01-2008, 06:06 PM
keliente's Avatar
If you don't have TCS, then you have nothing to turn off
Old 02-01-2008, 10:53 PM
chevguy86's Avatar
it has tcs someone before me took the fuse out of the fuse panel and i want to put it back in and was wandering if i could wire up a switch to turn it off when i dont want it
Old 02-01-2008, 11:13 PM
ae13291's Avatar
well just look for a connector behind the dash! it should be there if the car did have ASR! if not then its not worth converting
Old 02-01-2008, 11:16 PM
SovXietday's Avatar
If it has no fuse it has no power which means it's off. Camaro TCS is terrible anyway, I'm glad I don't have it.
Old 02-01-2008, 11:17 PM
intense3123's Avatar
even cars without asr have the wiring still behind the dash. connector and everything.
Old 02-01-2008, 11:24 PM
chevguy86's Avatar
so do i just look behind the panel where they would normally mount the switch
Old 02-02-2008, 12:32 AM
ae13291's Avatar
yea dident realize that! my car also has the wiring for the 12 disk cd player too!
Old 02-02-2008, 11:12 PM
chevguy86's Avatar
so i could just buy a asr switch and make it a neat and clean installation im gonna need it here in a few months
