Coolant Leak: Front Driver Side
Hi all,
I have a '98 TA, stock everything. I just developed a fairly significant coolant leak (1 drop/7 seconds) at the front of the engine on the left (drivers) side. It looks like it's right forward under the radiator and left almost at the edge of the headlamps. It's dripping out just inboard of the access panel for the headlamps. The waterpump is at the centerline of the car, correct? So would this indicate it's leaking from the radiator or a hose? I also noticed the coolant was green and for some reason I was thinking it was supposed to be using the orange. Any ideas about the leak location would be much appreciated. Thanks!
Q
Q
