Seafoamed my truck if you are on the fence DO IT!!!
Old 02-02-2008, 02:40 PM
no title here
skyhighsami's Avatar
Default Seafoamed my truck if you are on the fence DO IT!!!
Made a big difference!!!! Worth the time, that's all
Old 02-02-2008, 02:42 PM
z28berryhill's Avatar
i have heard it weakens the the rods on the motor...i was told that from a livernois motorsports tech
Old 02-02-2008, 02:54 PM
OMGWTFBODY's Avatar
Unless it was acidic, how could it weaken the rods?
I could see it messing with gaskets, but even then, not enough to make a difference unless they were already failing.
Old 02-02-2008, 02:56 PM
good point i was just sayin what i heard not necaceraly true
Old 02-02-2008, 03:08 PM
OMGWTFBODY's Avatar
Seafoam has a nasty reputation at Jeepforums. There's a reason for it too. The old 4.0s just don't hold up well over time. Most of these people have dead seals, and the seafoam cleans up the carbon that's holding the gaskets together and filling the gaps.
I know a few Jeep guys that seafoamed a motor and had to get a new one. All of those motors were at 200k+ and starting to fall apart. If they were clean there would have been blow-by and massive amounts of oil consumption.
Instead, they held together from the engine gunk.
Go Jeep!
Old 02-02-2008, 03:13 PM
no title here
Well m truck is 52k miles and it worked awesome! My wife's Yukon is close to 90k and it will be done when it get's out of the paintshop. My Camaro will also be done, along with my Samurai. I couldn't believe it.
Old 02-02-2008, 03:18 PM
OMGWTFBODY's Avatar
It's definitely a good things for a lower milage vehicle. I'm going to do mine before I change the oil/plugs in a month or so.
Old 02-02-2008, 03:20 PM
Siwel's Avatar
I have done it to all of my cars w/nothing but good results..
Old 02-02-2008, 03:22 PM
so my car has 90 k you guys would think its perfectly safe?
Old 02-02-2008, 04:17 PM
venomhp's Avatar
that would be fine, I have done it on a truck with over 200k and it was good results
Old 02-02-2008, 04:52 PM
ae13291's Avatar
seafoam also cleans the spark plugs too!
Old 02-02-2008, 06:37 PM
g-ryde1's Avatar
did it with mine at 100k no problems
Old 02-02-2008, 07:31 PM
no title here
And it will run better too!
Old 02-02-2008, 08:20 PM
Cumbias's Avatar
Would it be ok to use it only in the intake and nothing in the oil. It wont Leak into the oil pan, right? sorry, know very little about engines.
Old 02-02-2008, 08:41 PM
fuseone's Avatar
yea i dont see how seafoam will cause rods to go bad. even gm them selfs make a top end cleaners just like seafoam and it has no problems only way it will mess up the rods if you hydrolock the engine
Old 02-03-2008, 02:16 AM
Cumbias's Avatar
ignore my question. (dumb). . ..
Old 02-03-2008, 01:11 PM
Save the manuals!
wssix99's Avatar
I can attest that doing a cleaning on a low mileage engine is a great thing. (I have heard that it can cause leaks in high mileage engines where the gunk and deposits are making up for worn gaskets.)
I treated mine with the MotorVac CarbonClean system. From my reading, it performs similar duties as Seafoam. The downside is that you need to hook up a special machine to do the work. The upside is that the full cycle is complete while the car is in the shop - no worries about driving off gas, etc.
I paid a local shop $85 for the treatment and got an additional 3mpg across the board. Paid for itself in one road trip and was well worth the reduced effort.
Old 02-03-2008, 01:28 PM
_JB_'s Avatar
Go Jeep!
So wait, you say they don't hold up well over time but yet you mention 200K mile motors????
Old 02-03-2008, 01:58 PM
Z Fury's Avatar
I don't see me having the same luck with my truck. It has just under 195K on it, and I can guarantee that the engine gunk is holding the engine together at this point. I do plan on doing this to my car come spring time though - it has about 72K on the clock.
Old 02-07-2008, 08:45 PM
no title here
As I promised I Seafoamed the Samurai today. It is a 1990 and was never taken care of before I got it and I have had it since 01. It has had 3 motors in it and has always ran and idled very rough. Today after just spraying the Deep Creep in it, it started to idle smoother than it ever has. You should have seen the smoke coming out of it. HAHA!!
