How to remove the engine from the bottom - LS1 fbody - Page 2 - LS1TECH
Old 05-18-2016, 06:15 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
Closed Thread
Thread Tools Search this Thread
Old 02-04-2008, 04:39 PM   #21
keliente's Avatar
Quote:
Originally Posted by bjamick View Post
Well i actually finished my motor removal maybe a month ago. Well as i was pulling body up it forgot one of the connector and the thing split. It was connected to like the bottom passenger side of the block right by the starter i guess it might even be the low oil sensor. How in the world can I fix that bc i am no pro solderer so??
You don't have to be a pro solderer. Strip back both sides of the wire, slip some heatshrink over it, twist it together, and hold your soldering gun on the back of the wire for a few seconds until it gets hot. Touch the solder to the wires and it will 'soak' into the strands. After it cools, pull the heatshrink over it and heat it up.
keliente is offline
Old 02-05-2008, 12:13 AM   #22
Pontiacerator
RevGTO's Avatar
Great write-up, Kelly - thank you! I had just started searching on this and could not find a detailed write-up. Yours is perfect! Very carefully done and well written on top of that!
RevGTO is offline
Old 02-05-2008, 12:34 AM   #23
therobman's Avatar
that couldnt be any better nice tut could have use it a month ago lol
therobman is offline
Old 02-05-2008, 12:47 AM   #24
Prerun4fun13's Avatar
Quote:
Originally Posted by jermzz View Post
Great write up.
It gets a bit more tricky if you dont have a lift though lol
lol jacks and an engine hoist is an art...
STICKY!!!!!!!!
Prerun4fun13 is offline
Old 02-05-2008, 12:56 AM   #25
LilJayV10's Avatar
Nice write up. I did this on a 93 Z28 in a one car garage with a cherry picker and some jack stands.
My question is about the brakes. Do you have to take it to GM to bleed the brakes. The brakes on that 93 suck and I have bled them several times.
I am trying to talk myself in/out of a cam install on my Firehawk. If I do, it's coming out the bottom. I would much rather do that than out the top on one of these cars.
LilJayV10 is offline
Old 02-05-2008, 04:44 AM   #26
james562's Avatar
Guarenteed Sticky
Great job Keliente
What are your plans for the car? Why are you pulling the entire motor?
james562 is offline
Old 02-05-2008, 07:01 AM   #27
snake3126's Avatar
deff sticky material.. this is going to help me alot on my project
snake3126 is offline
Old 02-05-2008, 11:12 PM   #28
mchdg86's Avatar
You don't need to pull the motor just for a cam swap. Just take the radiator and fan assembly out and tilt the AC condencer up out of the waw and the cam will slide in and out with plenty of room.
mchdg86 is offline
Old 02-05-2008, 11:22 PM   #29
2002_Z28_Six_Speed's Avatar
Quote:
Originally Posted by blackangel327 View Post
No. You don't need the Tech 2.
2002_Z28_Six_Speed is offline
Old 02-06-2008, 06:35 PM   #30
keliente's Avatar
Quote:
Originally Posted by james562 View Post
Guarenteed Sticky
Great job Keliente
Well I'm doing a twin turbo kit, which requires changing the k-member...secondly, it looks like a pain to install the kit while the engine is in the car, so that's another reason it's coming out, easier to work on. Thirdly, I wanted to do an oil pump/timing chain since I never did them when I did my cam, and lastly I also have some 317 heads to put on.
So one thing kind of led to another, and at this point it seems a whole lot easier to pull the engine out instead of diddling around with it inside the car.
keliente is offline
Old 03-25-2008, 07:50 PM   #31
dave70's Avatar
A question on the brakes. Do you just bleed them normally? At the caliper ? And great writeup just in time. Also could you take out the bottom k member bolts first and the shock tower ones last? I don't have a lift and I'd rather not be under it when it comes loose LOL. Did you leave the power steering pump in the car or disconnect it?
dave70 is offline
Old 03-25-2008, 10:18 PM   #32
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
That's a very good write up. I usually just condense all that down to a few sentences. I like your last step the best though. That is indeed a true necessity. It depends on if you have traction control or not whether you have to use the special tool to do the brakes. If you have traction control you need a Tech-1, 2, or scan tool. If you don't have traction control you can just bleed them normally by following the right rear, left rear, right front, and left front process.
Beaflag VonRathburg is offline
Old 10-28-2008, 07:25 AM   #33
cpd004's Avatar
Isn't their a ground strap on the back of the engine/head somewhere that attaches to the body?
cpd004 is offline
Old 09-15-2009, 06:02 PM   #34
01ssreda4's Avatar
thanks to a great write-up.......success, and nothing broke.
01ssreda4 is offline
Old 04-12-2010, 08:08 PM   #35
ah HA! I thought you looked familiar! I am just gonna bring my car over to you when I get to this point fantastic write up!!
Meager is offline
Old 04-13-2010, 03:21 AM   #36
ЯєŧąяĐ Єlmиąŧя
orangeapeel's Avatar
After a few years I think its time to put this where it can be easily found. Especially since these 4th gens are getting older and are prone to needing swaps these days.
orangeapeel is offline
Closed Thread
Related Topics
Thread Thread Starter Forum Replies Last Post
Secondary Air: Diagnosing and Removal jg rider Generation III External Engine 8 11-30-2016 12:32 PM
Trap door/Racetronix pump/Hotwire kit INSTALL **lots of pics** NineZeroFive Fueling & Injection 15 08-17-2016 09:55 PM
'99 L36 V6 to '01 LS1 V8 swap (w/PICS!) ZexGX Conversions & Hybrids 58 08-01-2015 12:39 AM
How to install a 12 bolt? keliente Gears & Axles 21 05-18-2010 07:47 AM
My APS TT dyno results & info keliente Forced Induction 111 06-27-2008 01:11 AM
Tags
2004, bottom, chrysler, cruiser, engine, fbody, ground, hoist, keliente, ls1, ls1tech, pt, remove, removing, sensor, speed, strap, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
