Tune up needed. What to use?
Old 02-08-2008, 11:40 AM
pj4553's Avatar
Default Tune up needed. What to use?
well my car is due for a tune up after i get it back together. i'm around 100k.
what would you change and what brand would you use? i searched and didn't come up with what i was looking for. name it all.. fluids, plugs, wires etc.. thanks guys
Old 02-08-2008, 11:44 AM
cookba's Avatar
fluids depends on the purpose of the vehicle. redline and Royal Purple are safe bets
Plugs wise you cant go wrong with NGK TR-55
And wires, i have always like MSD
oil filter, K&N, WIX, FRAM, AC DELCO everyone will have a opinion on this.
I use G05 radiator fluid, just me though
ATE brake fluid
check out ws6store.com they usually have a good combo deal on wires and plugs
Old 02-08-2008, 09:39 PM
ghardester's Avatar
ATE brake fluid
This is good advice. There are a lot of brand opinions on here, kinda like discussing religion, everyone thinks they are right. The most important thing is to just do the tune up regularly. AC Irridiums are also good plugs, I use Taylor wires and like them. Be sure that you change the fuel filter. With 100k on it you should also change fluids in the rear end and manual tranny. If it's an Auto trans and hasn't been done it's over due. Check serpentine belt for cracks.
Old 02-09-2008, 02:45 AM
hammerdown2000's Avatar
agreed cant think of anything else off the top of my head! speaking of which i need to change my tranny fluid its overdue as well!
Old 02-09-2008, 02:50 AM
tspence45's Avatar
If you're doing a tuneup, I'd suggest seafoaming it before changing out everything. It'll get all the gunk buildup out of your motor. If you're going with new plugs and wires, WS6Store has a pretty good deal going on where you can get NGK TR-55's and MSD 8.5 super conductor wires for $70+shipping.
Old 02-09-2008, 04:37 AM
SlowSS416's Avatar
Autozone fuel filter, WS6 store plugs/wires combo, Mobil 1 Tranny and Rear Diff Fluid, New Air filter, clean the Maf. ohh and DEFINATELY seafoam BEFORE everything!
Old 02-09-2008, 07:42 AM
frisco88's Avatar
I used MSD wires and ac irridiums.Last plug passenger side a real biatch.Good luck
