squeaking wont stop!!!
squeaking will not stop, i have changed my alt., and my tensioner pulley! changing them two helped out allot, but still have that high pitch squeaking! i believe its the pulley that to the left (passengers side) of the underdrive pulley. its not on the serpentine belt system its on the AC or whatever that system is? what is that pulley called? is there a pulley system diagram or something i am missing out on? also what system of pulleys is that on called? thanks for the help guys!!!
i had that problem for awhile when i just bought mine, try changing the idler pulley, its a smaller one that has nothing running off of it, it isnt ridged and usually the bearings are bad in them, try a search for some pictures. other than that it might be your water pump???
get an engine stethoscope put the probe the brackets of the pulleys this will let you know which one is squeaking. btw there are 2 idler pulleys on our cars. hope this helps
I duno weve had a lot of car with squeaky belts, weve just taken a wax candle and with the car running put the candle on the belt and let it rub until the noise goes away....its worth a shot cant hurt anything..
I had the same squeaking at startup when cold and it ended up being that the belts were slipping, all I did was spray some belt conditioner spray that I picked up at pep boys, and at first it went from squeaking when cold, to a sticky belt sound all the time for a few miles but now its silent, problem solved for me.
Repack the idler pulley with new grease, then try repacking the two tensioner pulleys. There is a thread that shows how. There is one tensioner for the main belt and one tensioner for the A/C belt. Then maybe the alternator, or water pump, or even the power steering pump can squeak. Don't use belt dressing, it will just cause you more frustration.
Hope this helps.
Hope this helps.
