high idle need help...
i put on my long tubes and took out the AIR system, i plugged up the little hose to... since then when my car is at an complete stop it will idle normal... but when in gear or cruising in neutral my car tries to stay at about 1.5 - 2 rpms.. does anyone have any suggestions?
Its a 2001 m6. the only vacume line i disconnected was the little one that went into the T hose things for the air system. But after disconnecting it i plugged it.
