Coolant Concern
Old 02-13-2008, 11:46 PM
BuBbABFP's Avatar
Default Coolant Concern
Hey guys I just found out about 4 days ago that my car needed the Orange coolant.. well I have had my car for about 2 years and it has had the green one ever since and I have toped it off with the green one as well because I didn't know it needed the orange one. Should I change or just leave it? It has not giving any problems.
Suggestions?
Old 02-14-2008, 07:10 AM
discostu's Avatar
useing green will not hurt your system. i just switched over to the yellow it mixes with everything with no problems. there is a big discussion on the subject which is better green or orange but i think it is personal opinion. If you decide to stay green i would flush the system to be sure the switch was done properly and then put what you want in.
Old 02-14-2008, 07:25 AM
DaveH71's Avatar
yes there is no problem switching to green. Just make sure you have all the orange out of your system like what was said by doing a flush. I had a 98 s10 before my z28 and it used dexcool. After awile it just turned into sludge so i flushed it really good and cleaned the overflow bottle and switched to green.
Old 02-22-2008, 11:08 PM
wichoms4's Avatar
dude change it to orange. the reason is cause the block is aluminum and it runs hotter than an iron block. that coolant is ment to run with aluminum blocks. ill change it asap.
Old 02-23-2008, 03:39 PM
ae13291's Avatar
green has been around for more then 40 years!! aluminum and iron and everything! it works fine on mine! dont worry about it! and the green coolent runs a tad bit cooler then the orange! the orange dexcool is only good for the newer cars with the pressurized secondary tank! KEEP THE GREEN!
Old 02-23-2008, 10:57 PM
fuseone's Avatar
yea as long as you changed it to green and didnt just mix the orange and green togther you should be fine
Old 02-23-2008, 11:00 PM
01WS6/tamu's Avatar
Change the green antifreeze once every two years and you will be fine. It has been used longer in aluminum applications than most members here have been alive.
Old 02-23-2008, 11:10 PM
gold98Z28's Avatar
thats the main thing, as long as its not mixed, if you change one way or the other it must be flushed real good, together they gel up and clog the system, as long as its clean and fresh keep it till you need a change.
