Wind noise...
Old 02-14-2008, 10:53 AM
The_Wretched's Avatar
Default Wind noise...
how do you fix wind noise... like when you're goin' 60mph+(yes... windows up!! lol ). I only get it from the driver's side... it's not incredibly annoying... but it's there. how do you go about fixing that?
Old 02-15-2008, 06:50 PM
Spiers's Avatar
Im not sure if yours is the same as mine but even when my window is up, there is a very small open space at the rear that wind always comes in. Plus water at the car wash. Of course my door is shut all of the way
Old 02-15-2008, 07:59 PM
nickls1's Avatar
you ever condition your weather seals with dielectric grease? It helped out on mine. With both wind noise and leaky window by the t-tops.
Old 02-15-2008, 08:21 PM
TCW
TCW's Avatar
good tip, have the same problem above 75 and when it rains hard
Old 02-15-2008, 09:20 PM
PSU 98's Avatar
Most wind noise is caused by bad weatherstripping. Look for ripped pieces or pieces that are getting pinched around the door/window as well.
Old 02-15-2008, 09:22 PM
Wild Willy's Avatar
Make sure your door is hung correctly
Old 02-16-2008, 12:51 AM
Spink's Avatar
+1. Don't use vasoline! That'll make it worse.
Old 02-16-2008, 04:36 AM
SimC33's Avatar
Mine makes the same noise at about the same speed...mine is because the drivers side front part of the window doesnt go up all the way...check that...but i still dont know how to fix it :-(
Old 09-14-2008, 01:20 PM
maxgee's Avatar
Same noise here on driver's side front part of the window.
Taking a trip next may Fl to Ga and want to fix that before the long drive.
Quick Reply: Wind noise...
