winshield wipers stuck in up position
Old 02-18-2008, 01:13 PM
Hot Karl's Avatar
Default winshield wipers stuck in up position
Using my windshield wipers the other day and as when I went to turn them off, instead of going down, then went up and stayed there. Everything works fine, no wierd noises coming from the motor. Did a search and couldn't find an answer. Anyone know how to fix this? Thanks.
Old 02-18-2008, 03:56 PM
Z28Fistergod's Avatar
Mine did the same ****, here I thought I was the only one. I never figured out why that happened or how to fix it correctly. I fixed them, but I did it in a back-wods kinda way, I ended up modifying the internals of the wiper motor. PM me if you want the details.
Old 02-18-2008, 06:29 PM
joshp14's Avatar
Probably either the module or transmisson (park mechanism). I cant remember how the wiper system is setup on these cars otherwise I'd have a logical guess for you
Old 02-18-2008, 09:30 PM
ghardester's Avatar
I had the wiper motor on my '97 replaced at the dealer to fix this problem. That was before I decided to check things out myself. Besides, it was under warranty and didn't cost me anything. I wasn't going to drive around like a dork with the wipers up for long.
They told me that there is a stop of some kind in the assembly that breaks and causes the problem. Must be fairly common GM problem. Could be dealer BS too. Don't know.
Old 02-19-2008, 12:11 PM
Hot Karl's Avatar
It would appear that something is "backwards." If I have the wipers off and I move them down with my hand(they will go down with almost no resistance), they will come back up when they reach the bottom. It appears that the motor sees the stop at the highest point of the cycle now, versus the lowest point, like it should.
Old 02-19-2008, 03:28 PM
Z Fury's Avatar
Could be your car's way of waving to hot chicks.
Beyond that, it is definitely the motor issue. Either change it out completely, or PM Z28Fistergod and fix the one you have.
Old 11-15-2010, 03:32 AM
ccckeeper's Avatar
Got this same problem on my '98 ta. Did you fix this? I've ordered a new pulse module board from Rockauto, will let you know if it sorts it out
Old 11-15-2010, 04:23 PM
robertbartsch's Avatar
Pulse boards go bad a lot in these cars and water from car washes often get these parts wet and that does not help.
The mechanical piece above the wiper motor with the spring also casues the "bad" park issue discussed here. I just had this replaced and it is working fine now. The piece is a dealer only item at around $150 bucks a copy.
Old 11-15-2010, 05:15 PM
ghardester's Avatar
The '97 that I had with this problem was under warranty at the time and the dealer fixed it.
I was told that the problem is a design flaw that has to do with a weak positioning stop in the wiper motor that moves or breaks, or otherwise fails. So the wipers do not return to 'parked' position.
The dealer replaced the entire wiper motor, as I recall.
Old 11-17-2010, 04:37 PM
carguyshu's Avatar
most of the time when you by a new motor it comes with a new logic board. My car had the same problem where it would occasionally stay up and sometimes go down. Replace the both of them & you're good. The parts aren't all that much.
Old 11-17-2010, 04:42 PM
chaman's Avatar
Funny I saw a LT1 Camaro today with that exact same problem.
Old 11-27-2010, 11:10 AM
ccckeeper's Avatar
Unhappy
Well I've now changed the pulse board and ........... same problem. So getting annoyed with this now I guess new motor is the next step or/and switch.
Old 11-28-2010, 10:26 PM
ZeeVert's Avatar
Here's a picture of my Impala wipers; top of wiper motor. There's a TAB that gets bent and I've had to straighten it out twice in 140,000 miles. Maybe Fbody the same?
Old 12-01-2010, 02:13 PM
ccckeeper's Avatar
Thanks for the info. I will check this out as soon as it stops snowing here.
Old 12-12-2010, 01:09 PM
ccckeeper's Avatar
Ok changed wiper motor and all now ok. I think the problem was with the small springs on the park mechanism. Thanks to all for their help.
Quick Reply: winshield wipers stuck in up position
