Modded DRLS - LS1TECH
Modded DRLS
Thread Tools Search this Thread
Old 03-07-2008, 09:23 PM   #1
Joshiedoom's Avatar
Default Modded DRLS
So it has come to my attention that if you DD your bird that your DRL sockets will get ruined.. often.. especially during winter.. Ive replaced mine all too much and today I noticed that the socket is almost directly exposed to the lower bumper opening.. WTF... what a poor design.. SOOO
Im thinking new housings.. and getting two new sockets and putting them on top of the housing.. then expoxying a plastic template on the bottom to seal it up.. when the socket is on the bottom water can pool up(due to gravity) in the connectors.. seems like if it relocated on top that it would help with this...
FEEDBACK REQUESTED
Joshiedoom is offline   Reply With Quote
Old 03-07-2008, 11:22 PM   #2
1FST-Z's Avatar
Patent it, and ******' SELL IT. Fuh real. And do it for the Camaro as well, goddamn bulbs.
1FST-Z is offline   Reply With Quote
Old 03-07-2008, 11:41 PM   #3
Joshiedoom's Avatar
Ive replaced about 20 bulbs since october...
Old 03-08-2008, 10:23 AM   #4
Save the manuals!
wssix99's Avatar
Are your lenses good? Sounds like the bulbs are getting wet.
Being in the bumper, they tend to get hairline cracks in them which lets in water - which causes things to go bad. If any of your 20 bulbs have exploded, its definitely a water issue.
wssix99 is offline   Reply With Quote
Old 03-08-2008, 05:23 PM   #5
Joshiedoom's Avatar
Lenses are good. My car is a DD btw.
Old 03-08-2008, 06:00 PM   #6
NateLS1's Avatar
I just got new lenses/housings, new sockets, and new bulbs. I also put on custom cut clear bra to cover the lenses so rocks and crap dont crack them allowing water in. Done
NateLS1 is offline   Reply With Quote
Old 03-09-2008, 10:06 AM   #7
natels1 how much did all that cost you?
xterminator is offline   Reply With Quote
Old 03-11-2008, 01:35 PM   #8
99monguse's Avatar
Problem is that the sockets get wasted here are the part numbers for new sockets. The sockets have leads on them too.The bulb socket part number is 88986416 list $39.76 each(CAMARO)and part #12159662 list $64.65 each(TRANS AM) The Trans Am unit is a 3 way female with leads. This socket has the leads on it too. The price has gone up a bit since I did mine. The part number 12159662 will also work with standard Pontiac Firebird and FORMULA models. The Trans Am lamps are different(daytime lamps).
99monguse is offline   Reply With Quote
Old 03-11-2008, 02:08 PM   #9
Joshiedoom's Avatar
Autozone...10 bucks
Old 03-11-2008, 05:21 PM   #10
crazymofo1986's Avatar
whats the part number at autozone everyehere tells me its a dealership socket
crazymofo1986 is offline   Reply With Quote
Old 03-11-2008, 06:51 PM   #11
ae13291's Avatar
i never heard of this before! mine are good i even changed the bulbs and put brighter ones! and mine is a DD
ae13291 is offline   Reply With Quote
Old 03-11-2008, 06:55 PM   #12
phoenixv8's Avatar
yeah, sounds like your getting water in there. You might want to take the housing out to see where its coming in from. You can get them cheap on stealbay for about 25 or something.
phoenixv8 is offline   Reply With Quote
Old 03-11-2008, 08:25 PM   #13
Joshiedoom's Avatar
Any gm tailight turn signal socket..blade style type.. they have it in the electronics/fuses/bulbs/wire/toggle switch section
Old 03-12-2008, 12:32 AM   #14
Joshiedoom's Avatar
Poor Design is where the water is comming from
Old 03-14-2008, 02:18 PM   #15
LastHawk's Avatar
I just got my lamps and connectors in the mail today. I will definetly come up with something to keep the water out of there. You guys think its water getting into the housing AND/OR condensation collecting? It looks like around the base of the socket connection that there is a foam ring. sure it "may" keep "some" water out and also allow the water to collect and dry there... I dont know...
I'm just frinkin sick of changing bulbs every 2 months on a +30K car...
LastHawk is offline   Reply With Quote
Old 03-14-2008, 02:24 PM   #16
Joshiedoom's Avatar
Try moving it to the top. and sealing up the bottom'
Old 03-14-2008, 02:27 PM   #17
LastHawk's Avatar
I saw your other posts Joshie and will definetly think about it. I don't have a bunch of supplies or tools to work with but I may give it a shot withthe best of what I got. Very good idea...and Id be psyched to see how well it works.
Old 03-14-2008, 07:38 PM   #18
Joshiedoom's Avatar
A dremil and a file and a couple of hours should do it..
Tags
condensation, drl, ls1tech, replaced
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
