A/C Charging Question
Old 04-20-2008, 02:37 PM
shepuz2's Avatar
Default A/C Charging Question
I just bought some R-134 and was looking for the red/blue caps on the high/low lines and can't seem to find them......They were easy to find on my 2002 Firebird, but not on my 2000 Z28.
Thanks for any input.....Need to get a service manual in the near future.
Old 04-20-2008, 04:15 PM
BLACK2001SS's Avatar
The High pressure hook up is right below the radiator cap on my 01 dumdumdumdum and the low pressure is right on the dryer they are both small black caps.
Old 04-20-2008, 08:59 PM
tylerdj's Avatar
^^Thats correct.
Old 04-21-2008, 12:24 PM
shepuz2's Avatar
Uh-oh........charged it and still no cold air.
Doesn't sound like the compressor (clutch plate?) is coming on.
Maybe just a switch if i'm really lucky??
Old 04-21-2008, 12:37 PM
ae13291's Avatar
check the air conditioning relay, and double cheeck to see if the clutch is spinning on the a/c when u turn it on!
Old 04-21-2008, 12:40 PM
2001NBMZ28's Avatar
What was the static pressure just putting the gauge on? Depending on the ambient temp should be around 95 psi with it turned off. Maybe it was completely empty and the low pressure is keeping it off. Probably not it, but there's a couple fuses/relay you can check.
Old 04-21-2008, 12:56 PM
ae13291's Avatar
you have to also perge the air from the low pressure side too!
Old 04-21-2008, 01:27 PM
shepuz2's Avatar
OK thanks.......I bought it last year in the Fall from a dealership and can't remember if I ever used the A/C, so now I wonder if it even worked when I bought it? Buyer beware I guess.
Old 04-21-2008, 04:02 PM
tylerdj's Avatar
If the system was bled out, you'll need to make a vacuum before you charge it.
Old 04-21-2008, 04:46 PM
BlackSS2001's Avatar
how do you go about doing that? I'm haveing the same probs on my 01
Old 04-22-2008, 09:04 AM
tylerdj's Avatar
Are you asking how do you go about vacuuming the system out?
Old 04-22-2008, 01:17 PM
yeah. I had to replace a line after it blew. and I havent had AC since.
Old 04-22-2008, 03:49 PM
tylerdj's Avatar
I rented an A/C vacuum pump from Autozone. Just connect it to your high/low pressure ports, turn it on and once it's made a good vacuum in your system turn it off and take it back. Then just add the refrigerant. I've had to do this twice now and it's worked out fine both times.
Old 04-22-2008, 10:33 PM
MagnaTransAm0098's Avatar
you need to jump the ac compressor when you charge it..if you are charging it and it isnt kicking on then naturally it will not work. You can jump a relay but you can also jump the plug that is on the actual line..more towards the back somewhat by the computer. With the compressor running charge it with the air on..give it a few days if it doesnt work start looking for your leak.
Old 04-23-2008, 08:44 AM
shepuz2's Avatar
Well.......A local mechanic said there is no refrigerant in the system, but also no leak - as they checked it with a vacuum.
I just filled it the other day (or thought so) with 134, but maybe it didn't take? I think I put about 1/2 of a 12 oz. can in, and it never got cold.
Try it again?
I'm trying to save the $89 they want to do the A/C service at the shop.
THANKS.
Old 04-23-2008, 01:32 PM
tylerdj's Avatar
So did they say it had a vacuum in the system?
Old 04-23-2008, 09:38 PM
Pinky93's Avatar
I just charged mine up.... it has not worked since I purchased it last September. I bought (2) of the large cans at Wal-Mart with the included gauge and it took both cans to get it charged up. It blows VERY cold now!! I am out of town and cannot remember what size the cans of r-134 were, but it was much larger than 12 oz., so maybe you just need some more. Just make sure your compressor is actually cycling...
Old 04-24-2008, 01:31 PM
shepuz2's Avatar
As luck would have it......I filled the A/C with 2 cans of 134 and it did not hold - so there is a leak somewhere - even though a repair shop said the other day they vacuumed it and found no leak.
I guess I need to buy some of that 134 with the dye and check it out. If it is the compressor, I guess I am screwed out of a few hundred dollars.
Old 04-24-2008, 01:41 PM
BLOWNBLUEZ06's Avatar
Try it again?
THANKS.
I find it funny that an A/C system is " sealed " yet when all of the refrigerant is gone an shop says there's " no leak ". Even more funny when they charge you to tell you that! Makes me wanna .
Best way to find the leak is have a good, reputable shop overcharge the system with nitrogen and use a nitrogen sniffer to find it. Also look for dirt gathering anywhere on the connections in the lines and the compressor manifold. I have seen one leaking inside the dash which is difficult to find without a nitrogen sniffer.
