Old 04-26-2016, 01:27 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
Print Wikipost
Is changing my Automatic transmission fluid Good
Old 04-25-2008, 07:50 PM
02BlackMachine's Avatar
Default Is changing my Automatic transmission fluid Good
im about to change my fluids in my car and ive heard around u shoudnt change ur automatic transmission fluid because it would hurt the tranny, my car has 47,000 miles on it and im not sure if its a good idea, i need some 2 cents from ls1techers to very if its true .
Old 04-25-2008, 07:53 PM
954mula's Avatar
Whoever told you that is a full blown idiot. Change it every 15k miles or 1 year.
Old 04-25-2008, 07:55 PM
ae13291's Avatar
hell yea its good to change it!! well some cars that havent changed the tranny fluid for like 100,000 miles or so usally hav black fluid in the tranny and the fluid would smell lik clutch! the old dirty fluid and friction are what is barely holding that tranny together! i heard of some people changing the fluid and then there tranny goes out a day after! but in your case im sure this is not your problem as your car is healthy with those miles! but u will notice a much better shifting improvment when u change the fluid!
Old 04-25-2008, 08:04 PM
if i change it do i have to drive like a grandma for a couple of miles before it settles in???
Old 04-25-2008, 08:14 PM
TireSm0ke's Avatar
The only time I wouldnt change my tranny fluid is if the tranny was about to go... because like he said the fluid is the only thing holding the tranny together
ae13291's Avatar
this is how simple it is, you go under your car and remove the tranny pan bolts, and drop the pan, its better to do it when hot, that way more fluid will come out! then after the pan is off replace the filter and clean the magnet on the inner side of the pan! then put everything in and fill up to capacity from the dipstick and then you have to make sure all the fluids are topped off! and you can drive how ever you want after words
Old 04-25-2008, 08:16 PM
slowpoke96z28's Avatar
no. but you do need to correct whoever told you you didnt need to change it. theoretically, you cant ever change that fluid too often.
Old 04-25-2008, 08:17 PM
big to this though. this is the one time you wouldnt want to change it.
even in this case, you'd need to be saving up for a rebuild, lol. i doubt you're in that situation though.
Old 04-26-2008, 09:06 AM
staringback05's Avatar
just check your fluid...if its brown, burnt, and smells dont do it...if its normal pinkish/red, its fine to change...tech. dex 6 can go for a VERY long time...alot more then 47k...also depends if your usuing that synthetic fluid...i do mine around 50k or depending on how much i beat it...18 qrts of dex6 aint cheap
Old 04-26-2008, 07:51 PM
windshear's Avatar
I agree. If you have gone way past the change intervals, then don't change it.
Old 04-27-2008, 06:35 AM
Bird Man's Avatar
I change mine about every 30,000.
Old 04-27-2008, 09:45 AM
FiredUpZ28's Avatar
If you go past the interval just do a pan and filter drop. That way you don't wash anything out of there. I've done yearly pan drops on all of my cars and have never been a problem. if you experience any slipping - you already had a problem and the flush just made it more apparent. Just like the "synthetics cause leaks" fallacy.
Old 04-27-2008, 11:16 PM
bigfatls6's Avatar
Default Lwt mw add a little to it to help you
when you unbolt the pan loosen up the bolts on the front and remove them in the rear if your doing it on ramps or jack stands so that some of the fluid will drain before you drop the whole pan. You will also need to get the linkage tied or tucked over out of the way. Other wise your gonna have a mess. It will also be a hot mess if you do it with the car warmed up.
Old 04-28-2008, 08:27 AM
TXZ28LS1's Avatar
i also heard the same thing bout changing tranny fluid. ive heard alot of guys who changed the fluid and the tranny started slipping. then i also heard just change the fluid and not a tranny flush for these cars.
Old 04-28-2008, 11:15 AM
1994Z28Lt1's Avatar
asking if changing auto tranny fluid is good is the same as asking if sex is good
for the people saying that the tranny went to the ******* after they did a fluid and filter change, the only reason it did that was because the tranny was already in the *******, they would have gotten more miles out of it if they left the fluid alone but its still a ticking timebomb before it goes out
the thing i've noticed about transmissions is you either have to change the fluid religiously (30,000 miles) or not at all, the only problem is people forget and after 90,000 miles they do the fluid and its too late
Old 04-28-2008, 11:34 AM
tylerdj's Avatar
Old 04-28-2008, 02:32 PM
well then im on my way to change it ....dont want my tranny to go to waste ...preciate the help guys
Old 04-28-2008, 07:21 PM
slvr98camaro's Avatar
they arent an idiot at all, it is bad to change the fluid on a high mileage transmission, i would never ever change the fluid on a transmission with over 130k miles if it has never been changed before
Quick Reply: Is changing my Automatic transmission fluid Good
