Bright Light handle...HELP?
Old 04-30-2008, 09:19 AM
gnictry's Avatar
Question Bright Light handle...HELP?
Okay my bright lights work fine but just resently when you turn them on the handle doesnt let them click back off. So it clicks on and stays on ... if I mess with it for a while it well click back off...SO question is whats wrong and how do I fix it?
Old 05-01-2008, 09:32 AM
gnictry's Avatar
Default ttt
ttt
Old 05-01-2008, 01:56 PM
m2g4b's Avatar
okay i will give this a shot man.....first and most simple would be your lever is just broke inside the column....since you can play with it and get it to work, i dunno.....here is my suggestion that would rule out something else....take your lower panels off, drop the column brace and you will see a metal rod running down the column to your dimmer switch....the rod has to be seated into a notch for it to work right, and the switch itself has adjustable holes it is held down with, so maybe your screws have come loose and the switch slid back or the rod has just popped out of place....if you eliminate that, then you can go back to your lever going bad or something.....hope that helps a little man...
Old 05-01-2008, 02:15 PM
gnictry's Avatar
y ill give it a try ...wont be until sat at the earlest thou
