can i change my oil pressure sensor without removing the intake???
Old 04-30-2008, 09:38 PM
ae13291's Avatar
Default can i change my oil pressure sensor without removing the intake???
is it possible?? my pressure for some reason is always really high and i use 5w-30, so is it possible?
Old 04-30-2008, 10:13 PM
Dmoney's Avatar
No. You need to take the intake off.................
Old 04-30-2008, 10:19 PM
wtomlinson's Avatar
isn't there adapters to put between your block and the oil filter for sending units?
Old 04-30-2008, 10:28 PM
ae13291's Avatar
damm, i guess i could wait till i get my LS6 intake before i go off changing that thing!
Old 04-30-2008, 10:30 PM
Luna's Avatar
YOU CAN!
I have done it before with the intake still on so anyone telling you it can't be done is lying!!
BUT, that doesn't mean its easy. Gotta have real skinny arms/small hands and be able to kneel up on the lower airbox to get back there far enough. Its definetely possible, but its almost not worth it.
Old 05-01-2008, 07:16 PM
ae13291's Avatar
Originally Posted by Luna
YOU CAN!
wow sounds like a ****** pain! I would rather just leave it alone whatever! thanks anyways tho!
Old 05-02-2008, 10:23 AM
keliente's Avatar
YOU CAN!
Huge pain in the ***, but do-able...
Old 05-02-2008, 05:22 PM
staringback05's Avatar
id have to see a vid or pics...or im calling bs...not the smartest idea to replace a sensor that only holds onto the block, by a wafer thin piece without seeing what your doing...
taking the manifold off takes 15 mins at worst...
