Headlight stuck up.
Headlight stuck up.
A few months back, ... blah blah blah...
Replaced with brass gear, worked great for two months, and the epoxy seal gave way on the housing. Repaired with epoxy again and had great luck with the headlights working. Last week the car got lightly tapped (mild scrapes, didn't even crack fiberglass).
Now the driver's side headlight is intermittent. The light works fine, the connections and fuses are good. All of the grounds on the car appear to be intact and torqued down tightly.
As of yesterday, the driver's side will not move at all. I don't hear the motor struggling, or any grinding at all.
All of the rest of the electronics appear intact and functional.
Anyone got any ideas?
Motor housing is intact.
Lights are on.
Grounds and connections are firm.
Lights are on.
My driver side has gotten stuck/intermittent before. I've turned the manual crank **** slightly and it has worked for me. This is a light that I've replaced the gear on as well, not that it matters.
Check the voltage on the connector and check the connectors in the housing. I have seen these come lose and even corrode. I placed a small amount of HiTemp grease on the middle pivot on my linkage and that seems eliminate binding.
you might want to check to see if whenever you got bumped if the arm got pushed behind the bump stop. i replaced my passenger side motor a few weeks back and i tested the motor prior to it going on and it worked fine. when i put everything back together i had no noise, no movement or no grinding of the gear. when i tried to manually adjust it, it would feel as if i was forcing it to move and bind up. i then noticed that the arm was on the wrong side of the bump stop in the down position. check that and make sure that is not the problem.
