car wont idle after hooking pcm back up
Old 05-17-2008, 12:53 PM
xBROKEx's Avatar
Default car wont idle after hooking pcm back up
so i unhooked my pcm and tried one from another car to see if the tune would work. it would so i rehooked mine up and now the car wont idle. If i keep my foot on the gas it will stay alive, otherwise it just dies
Old 05-17-2008, 01:08 PM
9000th01ss's Avatar
Keep trying, it should relearn and run better within 10 -15 minutes.
Old 05-17-2008, 01:15 PM
xBROKEx's Avatar
tried that, didnt work
Old 05-17-2008, 01:22 PM
Luder[PAK9]'s Avatar
It may be that the position of the idle air control valve changed between PCM swaps and your PCM has no way of knowing this. Search for the procedure for resetting your IAC, that way both the actual position of the IAC and what the PCM thinks it is are the same.
Old 05-17-2008, 01:44 PM
xBROKEx's Avatar
nope, that didnt work
Old 05-17-2008, 01:50 PM
2001NBMZ28's Avatar
I'd try resetting the PCM and see what happens. No codes right?
Old 05-17-2008, 03:20 PM
xBROKEx's Avatar
i tried unhooking the batt and pcm for like 15 mins and rehooked it but still same thing. no codes
Old 05-17-2008, 03:36 PM
xBROKEx's Avatar
its also running really rich that may be because i have my foot on the gas to keep it alive though
Old 05-17-2008, 03:55 PM
xBROKEx's Avatar
also i can drive the car fine and it runs great unless i lt off the gas then it dies. could i have fried the iac?
