Do Mods put alot of stress on the engine?
Such as a very mild street cam, ported TB, ls6 intake..
Biggest concern is the cam.. It's a comp 224/224 .581/.581 114lsa cam.
It's been in there 20K miles and as far as I know its mild street cam, so I'm guessing it should be alright.
thanks in advance
thanks in advance
Kleeborp the Moderator™
With 20K miles, I'd at the very least change the valve springs for peace of mind. It isn't expensive (relatively speaking).
With a cam, you simply can't expect stock-like reliability, but then again, these engines tend to last a long time if properly maintained, even with cams/heads.
if he used stock replacement springs, your still going to need to get new springs to hold up to the higher lift of the cam. you really should just get a cam kit that comes with the new valve train parts your going to need. also do an ls6 oil pump and an ls2 timing chain.
