Power steering Reservoir
I found a while ago that it is leaking from somewhere so i cleaned it real good. Now i have found that it is leaking from the actual power steering reservoir cap. Is this a common problem? or should i get a new cap?
I've noticed the same thing. The top of the reservoir/around the cap always looks wet. Always thought thats just how it is, but maybe not. Would like to know if I need a new cap also.
Happens to mine also, first time i noticed i thought the Power Steering was taking a sh*t. When i took off the cap the entire bottom area thats covered by the cap had fluid sitting on it. Im not sure if the seal in the cap gets worn out or what, but it seems to happen to alot of them.
-Joel
-Joel
ps leak
my 99 z28 was leaking out the top too. turns out that someone filled it to the top and i guess the pressure was probably forcing it out? i took some of it out with a straw and sure enough.. no more leaks.. now its jus leaking from the rack and pinion boot which i heard isn't supposed to have power steering fluid..
Now that i know its a common thing and not really a major problem i feel better. Its a load off my back. thanks guys!!!
Hey your the guy with the cam and the straight pipes that i met at the last meet, arent you?....if not whoops..sorry.
if so...seeya at the next one!
-Joel
-Joel
