HEADLIGHT Probems HELP!!!!
When i push lock and unlock on the key pad both head lights flip up and down and i get this loud embarassing noise like a jackhammer from the drive side light. Both lights have no problem going up and down.Has anyone else had this problem?
http://www.bfranker.badz28.com/headlightfix/index.htm
go there and do the temp fix that will work or you can go ahead and buy the metal gear from there aswell
headlight
Hey thanks will replaces this weekend. Its weird cause it still moves up and down fine. O well that might be the only thing i havent replaced on that car.
hope it helps.
I didnt have luck since both sides of my gear were already worn out
I pay 5% over GM cost, and they were still expensive as hell...
103 for the driver side, and 99 for the passenger.
My headlight motor was so bad on the passenger side, that it just stopped going up.
It's been a while but I think it did that. It might only be when the foglights are left in the on position (normally just the parking lights flash) even though that shouldn't effect the headlights.
they can go up and down when you lock/unlock your car its a way you can set up your alarm to do that BUT if they do that and you hear a grinding noise in your headlights then its a sign that A. your headlight motor gear is wear out or B. your motor is going out.
they have the motors at Oreillys part number 49-125, i just paid 65.99 for it. Had to order it and was arrived next day. They are reman so far so good and with lifetime warranty it wears out go get a new one. When my drivers side motor was going out and i activated/deactivated my alarm, my lights went up and down same as you are describing. Replace the gear or the motor that will fix it.
Copy & Paste Moderator
There is a sticky at the top of this section called:
General Maintenance & Repairs FAQ -- PLEASE READ BEFORE STARTING THREAD
Your answer is in there.
