replacing the o2 sensors ?
well my car definetly needs new o2 sensors i got the codes read at autozone and all 4 o2 sensors came up as well as my egr i needed a new egr valve wich was replaced by a stealership and they said that i needed some o2 sensors and my SES lights comes on every now and then and i assume it is the o2 sensors
but is what i wanted to know is there any good right ups on how to replace o2 sensors? i have searched the whole sight and found information about o2 sensors but not a write up on how to replace them.
also how much do a decent set of o2 sensors cost?
thanks
-Adam
thanks
-Adam
Do you plan on getting long tubes fairly soon? If yes, do a search for Corvette o2 sensors.
If you decide to go with an ORY, you wont need new rear o2 sensors.
Replacing these sensors are easy, if you can turn a wrench and unplug something while the car is on jack stands in the air, you are golden.
Disconnect battery if you want.
Jack the car up.
Place stands underneath car.
Disconnect the sensors you are replacing.
Wrench off old sensors.
Repeat everything but in backwards order.
Jack the car up.
nope not planning on doing any mods soon, just trying to keep it running good, im off to college next semester so dont want to spend money on anythingthat isnt a necesite(sp?)
how much do 02 sensors cost ?
1 Post
there useless man, they are there only to sense if ur cats are working properly! but if ur cats ever clog (not a big possibility) it will tell u that its clogged, but anybody would know when the cat is clogged so its obvious, u dont need the rear o2's
