Clunking noise when i turn the engine off
Old 06-19-2008, 09:18 PM
badazz99ta's Avatar
Default Clunking noise when i turn the engine off
well my mods are in my sig. while the engine is running i have a ticking noise that sounds like an exhaust leak, but it sounds like its coming from the bottom of the engine. im pretty sure its related to the clunking noise. so when i turn the engine off there is a clunking noise that sounds it lasts for a half second. it sounds like the engine rotates one time after i turn it off and something is loose down there and it clunks. if yall want a vid i can get one up of the sound. i thought the sound was my lifters, but i think it might be a spun bearing. the engine runs strong. it will spin em in 1st, 2nd, and chirp em in 3rd. but i know that whatever is happening is robbing some ponies. my buddy has a '00 ss m6 with 3.73s, whisper lid, and a short stick and he can keep up with me and pull on me as soon as i hit 5th. and that shouldnt happen. thanks for the help and let me know if i can clear anything up for ya.
Old 06-19-2008, 10:56 PM
ae13291's Avatar
did u just install the mac mids?
Old 06-19-2008, 11:11 PM
badazz99ta's Avatar
nah. i bought the car last december and all the mods were already installed minus 4.10s, phb, and the short stick.
Old 06-20-2008, 12:12 AM
ae13291's Avatar
i hear there is a problem with the mac mids and the AIR pipes, those cause the check ***** to start making a ticking noise
Old 06-20-2008, 12:33 AM
badazz99ta's Avatar
well i dont have any emissions on the car as in no egr and no air system. its all been removed. ive still been doing research on here and i read a word that i think describes the noise when i turn the engine off the best. gravel, it sounds like there is gravel in the bottom of the engine when i turn it off. i hope this helps. thanks for the help so far bro.
Old 06-20-2008, 03:05 AM
ae13291's Avatar
damm gravel ehh? if thats the case, i would try to flush the oil first and see if i can find shiney metal in there, or check for exhaust leaks! put the engine under load and if u hear it getting louder it could be an exhaust leak maybe! did they use paper or metal header gaskets? gravel sounding noise sounds pretty bad man lol get it fixed asap
Old 06-20-2008, 09:02 AM
badazz99ta's Avatar
haha. i know man. im trying. i dont know if i should try to get this **** fixed or if i should just buy an engine on here from somebody.
Old 06-20-2008, 12:19 PM
ae13291's Avatar
maybe its some bullshit problem! unless it sounds crazy bad u kno the engine is gone. step one would be to flush the oil man, it doesent hurt to try! it might also be one of ur idler pulleys or a/c pully
thats seizing up maybe?
Old 06-20-2008, 05:15 PM
badazz99ta's Avatar
well its about time for an oil change anyway. so ill give it a go. and this might sound like a newb question, but how do you flush the oil. thanks bro
Old 06-20-2008, 05:40 PM
ae13291's Avatar
lol i ment as in drain the oil my bad! and new filter too!
Old 06-20-2008, 06:49 PM
badazz99ta's Avatar
ahhh haaa...you had to get all technical and fancy on me huh. lol. well ill get that done before my road trip tomorrow. later man.
Old 06-20-2008, 07:11 PM
ae13291's Avatar
cya good luck dude! hopefully u find the culprit
