how do i remove engine oil filler neck?
Old 06-22-2008, 01:01 PM
ae13291's Avatar
Default how do i remove engine oil filler neck?
i have been try to take it off, while the valve covers are off. it seems pretty loose inside but i cant get it to turn! does anybody kno how to remove it??
Old 06-22-2008, 01:06 PM
2002_Z28_Six_Speed's Avatar
A lot of people claim that if you remove the cover and use two small picks to lift up on the two tabs you can rotate it and get the filler neck out. I have never been able to get it out.
Old 06-22-2008, 01:10 PM
2001NBMZ28's Avatar
Haven't looked at one in a long time, but if I remember correctly there's a tab(s) to depress from inside the cover.
Old 06-22-2008, 01:56 PM
ae13291's Avatar
^^^^ thanks guys i had already figured it out right after i posted this, there is one tab inside that u lift and turn and the whole thing unscrews out!
