Got a few issues to work out, need feedback
Old 06-28-2008, 08:19 AM
Mid
Mid's Avatar
Default Got a few issues to work out, need feedback
I just picked up an '02 WS6...When I turn on the headlights, they flip open and won't stop so I get that loud jamming noise for a few seconds then finally stops....How do I fix that? And what size bulb do the headlights use? One of the bulbs is out. I don't have an owner's manual.
What are common problems with the power seats? Mine don't work.
The owner put a textralia clutch/flywheel in. Is it normal to hear a short whirring noise when going from a stop? Maybe any vendors can shed light on this?
Any feedback is appreciated, thanks.
Old 06-28-2008, 08:27 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
See the thread below about the headlight noise
https://ls1tech.com/forums/pontiac-firebird-1967-2002/177470-firebird-headlights-all-comments-questions-regarding-headlights-go-here.html
The headlights are sealed beam(I think), a new one is $25 at Wal-Mart
Check the pwer seat fuse in the fuse panel inside the car. It's silver, replace it and see if that corrects the problem
Old 06-28-2008, 09:55 AM
proelky's Avatar
*The headlight issue is due to the motor needing adjustment.
*+1 on the pwr seat relay/fuse.
*I'm running a Textralia with no noise issues. I do have issues when it's cold outside, but still no noise from it. It sounds like your slave cylinder needs to be replaced.
Old 06-28-2008, 04:38 PM
Mid
Mid's Avatar
Cool, thanks for the info...which fuse am I looking for?
I'm going to bring the car to a shop to look at the clutch issue....in first gear when you roll off the line it whirs for a second or 2.
Old 06-28-2008, 05:30 PM
bad2dbone's Avatar
New Headlight Motor Bro
Old 06-28-2008, 06:55 PM
Mid
Mid's Avatar
ok, so I took off my headlight and I'm ready to rotate the motor shaft 180 degrees.
But how the hell do I know how far the motor shaft is turning??
Old 06-29-2008, 12:34 AM
Mike44138's Avatar
Power seats are on a relay, also tied to the rear defroster. Check the relay. It's not uncommon to see the rear defroster trip the break under normal operation and the power seat not work until the breaker resets.
Old 06-29-2008, 09:05 AM
Mid
Mid's Avatar
Ok, I'm a newbie to this car...how do I check the relay? I'm not sure what I'm looking for.
Old 07-03-2008, 03:59 PM
Mid
Mid's Avatar
? help
Old 07-05-2008, 08:01 AM
Mid
Mid's Avatar
anyone know?
