Hey does anyone have a problem with "weighted steering"aka underboosted?
Old 07-04-2008, 10:42 AM
onebadazzls1ta's Avatar
Default Hey does anyone have a problem with "weighted steering"aka underboosted?
My steering is hard has hell to turn sometimes I have the fe2 I dont think that matters thought. Basically it feels like it's underboosted anyone have this problem? Does the suspension package matter?
Old 07-05-2008, 12:49 AM
newton's Avatar
Does the steering pump make any noise?
Old 07-05-2008, 07:47 AM
SladeX's Avatar
I noticed that on a friend's car, just a bitch to turn. Driven quite a few LS1 cars and know that it shouldn't be that hard to turn.
I'll have to check it out later to see if an underpulley is the cause as there was plenty of fluid in the system and the PS pump seemed not to make any strange noises. No coolant mix either, it was just oddly tough to steer.
Old 07-05-2008, 12:07 PM
SparkyJJO's Avatar
Mine was that way for a little while. Replacement motor had a pump with it that sat for a while so it was tight. Works fine now once it loosened up.
Old 07-05-2008, 06:12 PM
Nah it doesn't whine and I've very nearly owned my car since feb it's just very weighted and hard to turn especially when backing up or doing a u turn.
Old 07-05-2008, 09:26 PM
Reject's Avatar
need to start lifting weights or get skinnier tires for the front
just a thought but you could lift the front and suspend the body so the tires rotate freely while someone turns the wheel while you check to see if anything is binding underneath, just a thought
Old 07-06-2008, 01:51 AM
DrivenWS6's Avatar
Check the caster. I am not sure how much adjustment if any there is on our cars but if there is excessive caster in the front wheels it will turn hard.
