Whats Wrong with my car? please help
ok well idk anything about these cars im used to carb engines so i took a video of what was up and idk whats wrong anything will help replaced a few things if u name them as problems ill say
99 T/a A4 engine/trans all stock
http://www.youtube.com/watch?v=tXn3m9ZFuEU
http://www.youtube.com/watch?v=CuMgfvuZ5YM
In the video are you pressing the pedal...what I mean is does it do that when you let off the pedal or if you hold it in one spot? Is it any different if you shift into 1-2-or3 rather than overdrive?
It would be easier if you told us what you replaced...and if they arent major things I would start putting the stock stuff back on and see what changes it.
Wish I could help more...
the only thing that is done to it is the lid has been cut on the bottom piece
in the video the pedal is being pressed down about 1/4 but it does that crap
i never hear anyknocking that i know of
and as u can see flooring it does NOTHING at all it just revs up like its in idle barely moving
no my cars stock height and the lids been cut for quite sometime and it dosent hardly rain in texas and when it does theres no puddles but i havent driven it in the rain and its ran fine just recently got bad
This kind of response makes me think you should just take it to a shop and quit ******* wasting your time. Theres a lot to diagnosing a problem and doing it correctly is very important.
Check your plugs and wires to make sure that your seeing enough spark. Also, you said you have no cats so your seeing 02 codes, but are you using 02 sims or did you just remove the cats and 02 sensors? If so that may be messing your car up. Finally, id say maybe replace the fuel filter and have your fuel pump and injectors tested. Other than that no idea with no codes, could be anything...
well the fuel filter was replaced about a week ago and at idel it will idel for a lil bit then it slowly dies
The Maf was changed about a month ago and it was brand new
Btw 9000thss im only 17 and i posted this in newbie tech for a reason (it was moved) i will take it to the shop but why waste the money when theres a chance someone on here knows how to fix it...
I am kirkjames's dad, the driver on the video. I just barely push the peddle down and hold it and the car responds by rev'n up and down, nothing consistant till you lay into it and it decides to respond. WE have replace the TPS sensor and the MAF sensor and also a new fuel filter. Will go and have the pressure checked this evening and will post. Seems the likely culprit but we shall see. New plugs and wires will be replace shortly but would find it strang to get this kind of response all of a sudden. Anyone know what the normal fuel pressure is?
Fuel presure tested was 18. Obviously need a fuel pump. Local NAPA Auto parts had one for a bit over 300 bucks and was manufactured by "Carter".
Any suggestions on type and where? Should we go back with a delco? Are there any as good with a better price? Sure I could look but you guys have the experience. I have no problem replacing parts on my 72 mustang. The electronics on these vehicles are great but when they mess up, cha ching!
