cruise control wont work?
ever since i bought my car cruise control hasnt been working, ive been just fixing little things as i find the time and im ready to work on it, i dont know why it wont work i push the button and nothing happens no light in the cluster or anything. any suggestions??
+1 fuses would be a good start, also make sure the cruise control is actually on (not calling you stupid or anything) i know thats got me a few times when i hit the selector button an don't notice it.
Chances are it's just the kill switch under the clutch pedal. It's a push pin looking switch that contacts the shaft of the clutch pedal. If the clutch pedal is beginning to sag or the return spring is broken, the pedal shaft will push in the kill switch. The distance between the switch and the shaft can be adjusted by screwing the switch in further. It's got a threaded barrel on it.
Thanks for the tip!
